95 4wd problem
Old Mar 10, 2008 | 01:18 PM
Ford347's Avatar
Ford347
95 4wd problem
Hi I have a 95 f150 4wd 5.8L auto, Im having trouble with my 4wd I push the button on the dash and it doesnt go into 4wd could anybody give me suggestions on where to start looking. Do thwese trucks have an electric accuator on themfor the 4wd?
Old Mar 10, 2008 | 08:23 PM
mstromni's Avatar
mstromni
yeah. It's bolted to the transfer case, it takes about 2 minutes to replace, and costs about $120
Old Mar 13, 2008 | 10:27 PM
Ford347's Avatar
Ford347
Is this usually what the problem is
Old Jan 29, 2009 | 11:36 PM
Ford347's Avatar
Ford347
Ok so i got checking things out, the motor is working because i can hear it and i grabbed the shaft and it was locked in. So when I went to drive the truck i cranked it to one side and drove ahead and I did the same in the other direction then i went straight and punched it a little and I gto nothing out of the front wheels and this was al while i was on snow and ice in the shop yard. What could be the problem any ideas???
Old Jan 30, 2009 | 12:45 AM
Gramps86's Avatar
Gramps86
if your transfer case is indeed enguaged then check your hubs, im assuming you have the autolock hubs with that electric 4x4.....
Old Jan 30, 2009 | 07:40 AM
cjben's Avatar
cjben
like gramps said,check your hubs. you didn't mention if they were manual hubs or not,but if they are manual,make sure they are locked in.
Old Jan 31, 2009 | 01:09 PM
Ford347's Avatar
Ford347
yes they are the autolock hubs, is it possible that they arent working?
