97 explorer 5.0-Will not start in cold weather
It cranks fine, It acts like its not getting gas, but I do hear the fuel pump, and when the weather is over say 35 degrees it starts fine. It is the big 8 cylinder, the last time it would,nt start i got code p0153 which is why I changed the dfpe sensor. I would appreciate any help.
Thank You
Thank You
the egr valve would not keep your truck from starting. you can try the fuel dry but i don't think that will fix it because if you had water in the line it would run like crap no mater the temp. when it will not start you need to find out what system is failing. spark or fuel. pull a plug wire off and put a spark plug in it and ground out the spark plug on something metal (not painted). or you can spary starting fluid in it and see if it will start. just because you haer the fuel pump does not mean it is pumping. you can get a fuel press. guage from advanced auto for $20. put it on when it won't start. find out what system is not working then post back and i will get you to the next step.
mmgsport
15
12-10-2021 07:50 AM
makuloco2000
01-27-2014 10:34 PM
John7894
01-03-2013 06:51 AM
2000150
01-10-2012 01:03 PM
roree
01-07-2010 12:49 PM
