no power to fuel pump
need help, we can not get power to our fuel pump on a 00 PSD. So far we can run hot wire and it runs just wont come on with the key at all. I have changed relay and fuse is good, fuel cut off switch on right side kick panel has been checked also, can those go bad? I have to be missing something but what else is there that controls these pumps???
Originally Posted by guzzle92
Check the inertia switch in the passenger's side kick panel. It's rare but they have been known to go bad. A voltmeter would be handy to troubleshoot where you are loosing the voltage.
Originally Posted by F350-6
Welcome to FTE.
It sounds like fuses, relays and chaffed or shorted wires is where you should be looking. Are there any other symptoms or problems your having. What happened to cause this problem?
Maybe the attached info will help a little.
Do you know where the FPM circut would be or have a schematic???
jumbofordman
02-02-2015 05:15 PM
mitchgordon96
12-02-2014 01:10 PM
strokerspeed
50
09-16-2011 07:39 PM
cometobanks
12-04-2007 09:13 PM
MikeFlorida
02-21-2007 09:27 AM
