NEED HELP Chipped tubo vanes !
Last night while installing new intercooler hoses from Dieselsite ( nice quality hoses ) I noticed that 2 of the vanes on the turbo were chipped and 1 was slightly bent on the tip . About a week ago I started noticing a high pitched whinning sound around 2500+ rpm's I thought it was a leaking intercooler hose since I have been having issues with them leaking but after the new hoses it leads me to think that it's the turbo vanes ? What do I need to do with the the turbo ? And what could have caused this to happen ?
on
Originally Posted by Planeoldguy
thats a stock wheel..if your going to replace the wheel..and if your going to chip the truck...its best to go with a wicked wheel to get rid of the surge..
http://www.xtremediesel.com/index.as...ROD&ProdID=260
The whistle could defanitely come from the unbalanced or different pitched blades. Put the DP on a higher program, go into OD at around 1600-1800 rpm, and then roll into the the throttle and build boost without downshifting. It is much easier to get surge with a load on. You should begin to hear a chuff chuff chuff sound that kinda resembles a pressure cooker bleeding off. I can do a new wheel for you, but if you feel like pulling the turbo and doing it yourself, its not a HARD job to do in a few hours. It will give you some more sound, it sounds awesome.
on
The Wicked Wheel<SUP>®</SUP> will:
- Reduce or Eliminate Turbo Flutter/Surge in your 1994-2003 7.3L Ford Powerstroke.
- Lower Exhaust Temperatures - NOT increase them
- Increase Low-End Throttle Response - you may "feel" like your truck has more HP, but it DOES NOT
- For use in 1994- 2003 7.3L Ford Powerstrokes
- Is NOT intended as a horsepower mod.
- Increase your performance
- Increase your truck's horsepower
- Increase or decrease boost
- Increase or decrease fuel economy
Thor'sHammer
05-09-2015 04:50 PM
MoyockPowerstroke
07-29-2009 08:38 AM
