My ABS light has been on for some time now. I've checked the fluid level in the master cyclinder and all is good. You guys have some suggestions on where to start troubleshooting?
The ABS system will do a self test, but it is not the same test as the engine computer. I don't know for sure on a 94, but on my 87 there is a black wire with an orange tracer down near the parking brake pedal with an open connector on the end. If you momentarily ground that wire while the ABS light is lit, it should signal the ABS computer to blink codes on the ABS light. I don't know code definitions or if the wire is in the same place on your truck as mine, but I know that it is possible to get codes one way or another.
If the MC is full and the pedal is firm, I'd bet you've got a bad sensor. I've personally known 5 F-150s in this body era and everyone needed a new RABS sensor in their lifetime. I just replaced mine last week. It's cheap and easy to fix. $15 for the sensor at Advanced and 5 minutes by the rear differential and you're done. See here for how to do it: http://www1.autozone.com/az/cds/en_u...rInfoPages.htm
You mean the wheelspeed sensor on the rear end? It's probably fine if there are not issues with the speedometer....
The RABS sensor does monitor rear wheel speed and adjusts brake fluid pressure to the rear wheels in the even of a lock-up, but is not tied into the speedometer at all. All it does is monitor and adjust in case of a lock-up. I just replaced mine last week (which was bad) and had no issues with the speedometer. I also replaced the one in my brother's 96 - again no problems with the speedometer.
The RABS sensor is different form the Rear Wheel Speed Sensor found on 4-Wheel ABS vehicles (93-96 Bronocs and F Super Duties).
There are 2 lights that can come on, the one on the right of the wheel and the other is a dimly lit parking brake light (even if the brake is dis enguaged)
Most of the time it is 1 of 2 components,
1 (the parking Light) will be the rabs pump itself (in the frame, driverside, around the pedals section.) The valve in the pump gets stuck open internally, sorry but they are not servicable and quite expensive unless you find a boneyard with one. Try tapping them with a hammer to disloged the valve , you will need to bleed the system, there is a bleeder valve on the pump also.
The other is the ring gear sensor in the differential ( driver side , on top of the rear chunk.)
Pull it out and wipe it clean, it has a magnetic feild to it and picks up gear particals somtime causing it to malfunction.
If both of these are good , then It could be the RABs computer it self (under the kick pannel above the gas pedal, just to the left of the radio)
On 92-96 trucks, the same speed sensor feeds the RABS, the PSOM (speedometer/odometer) and the engine computer. The older 87-91 trucks had two separate wheelspeed sensors, one for the RABS, and one for the engine computer in-line with the speedometer cable.
Then I learned something new today. I always assumed the speed sensors for the speedometer on all 87-96 pickups were located in the transmission.
Still, the ABS light in my 93 and my brother's 96 were both on as a result of a bad RABS sensor in the rear differential. Neither truck were having any problems with the speedometer. Pulled the sensor in mine just two weeks back and had to replace. No problem whatsoever with the speedo, just the ABS.
When I bought my 92 F250 4x4 the ABS light was on all the time, along with the Parking brake light... I disconnected the battery to work on something else which I assume reset something with the computer.. the ABS light is no longer on, however the parking break light is... Just haven't looked into that yet.
I doubt any of the RABS sensors actually needed to be replaced. They are so simplistic it's hard for anything to fail. It's just a magnet with two wires coming off it. Sometimes metal filings will collect on the magnet sensor and that will confuse it enough to throw a light. Most of the time the fix is to just wipe it off with a rag.
I REALIZE THIS POST IS OLDER THAN DIRT. However, I have an 87 f150 4x4, and located the black wire with the orange tracer. However, when grounded as described, the ABS light remains on and doesn't even flicker. Do you have any suggestions??
Check the wiring connection at the master cylinder. The pins had pushed out of the plastic connector on the wiring harness on my truck. I had an ABS light and could not get codes either, then I found the issue with the master cylinder connector.
