Hey, we all feel it. RUL gas today is $3.49 while ULSD is $4.05. I just don't see a point to grousing about it. Actually, I'm feeling kind of proud that CA is not that much higher than the rest of the country. We usually get screwed the deepest but this time the pain is spread around.
Bill
I believe the percentages given reflect how th oil compnies have elected to "crack" the barrel of oil, not what can be gained from the barrel of oil.
Actually...it's to bad that fuel has to cost this much. It was mentioned that it will effect consumer goods...actually it already has. The prices at the grocery store have gone up...and now we get to pay more for that too.
You have the answer to your question in your own chart. In the winter, diesel production is cut back and home heating oil is the favored product. It's been a cold winter, so demand for heating oil is very high.
Incidently, my home heating oil has gone fron $2.15 a gallon to $3.25 a gallon this winter. At 200+ gallons a pop, that hurts.
And the reason for the spring price shocks? Analysts say it's linked to a shortage of alkylate, a little-known and expensive gasoline additive that some in the industry are calling "liquid gold." It has become a must-have ingredient since refiners stopped using MTBE two years ago when the potentially cancer-causing additive was found to be seeping into ground water.
The government taxes gas which raises the price. Then the government says they have to put in additives which raise the price. Then the government says they can't use certain additives which raise the price.
I think the answer to this problem is more governement.
That's correct, and is the traditional reason it's high over the winter months. But it doesn't explain why it's $4/gal this winter. Two reasons for that - first is the weak US dollar, and world prices are set in our own currency. Second, oil is the new real estate which was the new tech stocks. Money that was in the tech sector in the 90's went into real estate in the early 00's. Now that's not attractive so investors are putting money into oil futures. There are many more reasons, but those two are big ones.
Everybody loves to blame OPEC, or "big oil". But in fact OPEC is pumping enough to keep the world well stocked with crude. There is no shortage of crude, so while it's fun to poke GWB in the eye because OPEC won't increase production, they are pumping to meet demand and they don't dictate crude prices. The oil companies don't set the price of crude either.
This will all turn around as the economy slows. Fuel won't be cheap, but it will come down as demand slows.
Let's keep this in perspective. If diesel were $3/gal instead of $4/gal, the difference is about $30/fillup. I spend more than that on a cheap date. I just don't get all the whining. Spend $50k on the best truck the world has ever seen, and bitch-****-moan about an extra $30 to fill it up.
If you think fuel is high now, what do you think it will be with Hillarobama at the stick? They are both just looking for a way to make you use less while paying more for it.
Billl
That won't be the only thing that either one of them does either that will cost us more.
