Core Support Bushing Question
Does anybody happen to know the thickness of the bushing that goes between the core support and the frame, and the one under the mount? And possibly the size and lengths of the bolts used? I have access to materials to make the bushings, and practically any size bolt I need, so I just can't justify spending $70+ on a bushing set. Plus I just like making things.
I would measure mine, but they have deteriorated beyond recognition.
Thanks again for any help
Thank you for the responses, I am having a heck of a time figuring out exactly what I am going to do. I just spent an hour at a junk yard that said they had some for $20 only to find out all of theirs are rotten too. I just can't justify spending the $92 that they have listed on the Bronco Graveyard site, and LMC is outrageous priced also. Has anybody on this site come up with a design or method for making a cheaper version of these?
I have some ideas of what I am going to do, but just didn't want to go about it completely wrong.
On the Jeep, I got some 3/16" steel plate, and took a 3 1/2" hole saw, and cut some washers.
Then I cut some 3/4" high density rubber sheet with the same hole saw. Makes lots of smoke, so do this outside
Then I took a slightly larger than 5/8" drill, and cut center hole of the washers and the rubbers.
I sandwiched the rubber with 2 washers and ran the bolt down through everything.
www.Partsgeek.com has Energy Suspension ones in Red/Black colors for $63....
I've did a lot of business with them.....Great company as far as I'm concerned....Cheap shipping also...
A big thank you to everybody who helped give advise. I was able to get the core support swapped out this weekend. Instead of buying new bushings, or using hockey pucks, i used a pair of bushings from my old radius arms, and a set of hard rubber bushings on the bottom. Then i bought some 4" grade 8 bolts and a variety of washers, and got it almost exactly where it needed to be. My truck no longer looks like the front end is going down hill. All in all I think I had about $10 dollars in my core support bushings, $30 in the core support, and about $10 in paint and bed liner spray to try to prevent this from happening again. Definitely not a bad deal.
BrendanT7
04-03-2019 09:00 PM
jhorst14
02-09-2017 12:08 PM
JB78f150
03-20-2012 12:50 PM
