Diagnosing a problem: Help needed!
Old Mar 7, 2008 | 09:39 AM
Dave S's Avatar
Dave S
Gents,
I have a 2001 F-250SD, 5.4L w/ the ZF 5 speed manual box, and 125k on the clock. My question pertains to the clutch/slave cylinder. When I shift gears, the clutch pedal does not always return fully out. There's no slipping in the clutch, so that leads me to believe it's the master/slave cylinder. The clutch is the factory clutch.
Winter/cold weather it seems to be more pronounced, but not always a problem. Under hard accelleration, it's about 75% to return fully out, but under normal driving, it almost always requires a toe under the pedal to "lift" it up fully.
Summer/warm weather, it's not nearly as bad, requiring about 20% of the time lifting the pedal out under any condition.
Any ideas? Solutions?
Thanks,
Dave
Old Mar 7, 2008 | 11:51 AM
andym's Avatar
andym
If you have water in the line (brake fluid absorbs water) then it could be freezing causing the slow return. I had a truck that did that, but I moved to a warmer climate instead.
Try bleeding the clutch until you get fresh fluid coming out of the bleeder.
If that doesn't help, you may just have a weak return spring on the clutch.
Old Mar 7, 2008 | 06:44 PM
80351's Avatar
80351
Andy,
that's a heck of a reason to move to a warmer climate.
Old Mar 7, 2008 | 06:47 PM
andym's Avatar
andym
It was worth it too.
Old Mar 7, 2008 | 06:54 PM
80351's Avatar
80351
Where did you move from?
How much do you know about t-cases?
Old Mar 8, 2008 | 12:21 AM
Dave S's Avatar
Dave S
Sorry, no transfer case on my truck.
No... No water in the fluid reservoir.
