PCV Elbow Removal
Old Mar 6, 2008 | 10:02 AM
randinow's Avatar
randinow
PCV Elbow Removal
Hi, I have a 2003 Expy 4.6, and had the 0171 and 0174 codes...found the problem, the PCV Elbow behind the intake, right under the fire wall....my question is...how do I get the darn thing off...when I push on it it moves, but the elbow is also collapsing....I can't seem to push it enough to get it out.... any ideas??
Old Mar 6, 2008 | 02:59 PM
buzzard's Avatar
buzzard
I've never done mine, but I believe it's done as a complete assembly with the part running something like $30 from Ford.
Old Mar 6, 2008 | 08:47 PM
sbclemens's Avatar
sbclemens
The heat of the engine really creates a tight seal on the hose. Since its probably bad anyway, try lightly gripping it with a pair of pliers and twist it to break the seal. You should then be able to slide it off.
Old Mar 6, 2008 | 09:26 PM
randinow's Avatar
randinow
no room to twist it with pliers, it was basically melted to the fitting....I eventually got it off by cutting into two pieces, then it fell down in the engine compartment...so I couldn't find it to see what I needed to buy...but just got a heater hose and that worked....
Old Mar 6, 2008 | 09:55 PM
73f100shortbed's Avatar
73f100shortbed
I did a repair for a customer a few weeks ago and just used some 90 degree rubber elbows I found in the Help! section of Autozone. Only cost a couple of bucks instead of getting dealer parts.
