1968 f100 being towed with a tow bar
I have been reading different Posts about this and need some clarification!!
i am going to tow a 1968 f100 short bed with a Tow bar using a 2001 f150 4.6? what is the best way to do this. I am going to be towing it about 1200 miles? do i have to remove the driveshaft. what should i do to be able to tow this truck?
Quick question? Is it a manual or auto? Manual is O.K. to flat tow. Auto you have to drop the drive shaft. Otherwise you will burn up the tranny sense the oil will not be pumped out into the cooler or radiator. Also be very careful when braking! These trucks are darn heavy! And do not exceed 55 mphs or when you do it will start to fishtail!!! To correct the problem just ease of the gas and DO NOT SLAM ON THE BRAKES!!!! everything should be O.K. Good Luck!
Them 1200 miles....how many up hill? How many down hill?
Brakes on a 2001 F150 up to the job?
Trailer has brakes:
http://www.uhaul.com/towing/
Yea, I know, it costs money. Compared to the value of the two trucks and your life, weigh it out...
Trailer has brakes:
id use a trailer then you wont have to worry about old junk tires on the truck blowin out or brakes hanging up ect ect. if ya dont have a trailer just do the u haul thing if the trailer cost to much at least try and get a car dolley thats how i got my 71 from Tx to wi was a u haul dolley theyll tell ya it wont fit but they do
i would have to agree with doing the u-haul rental..it is much easier..when i got my truck i had to pull it 300 miles home..borrowed my brothers f250 diesel,rented the trailer,used a tractor to push onto trailer since 3 of the 4 tires were flat..i would be very uncomfortable flat towing it because of the weight.
I towed a 1980 f150 2wd about 50 miles with 1993 f150 4wd. Took the driveshaft off from the diff. All went well until I came to a curve. Went around a 45 mph curve doing about 35. The rear truck started pushing the front truck. My guess is the rear truck did not want to turn that curve at that speed. Stopped about 2 miles later at a gas station, cleaned my shorts, got a cup of coffee to take a breather and slowed way down on the next two curves. My advise rent, borrow or what have you, but get a trailer.
Not to many people understand that until you get behind a wheel and the only thing thats power is your forearms
