2001 F350 7.3 power stroke diesel is stalling,
Usually with the CPS going out the truck will just die, then start back again. Sometimes it will not start back. But with you saying it is sputtering before it dies, that might be a fuel problem. Change the fuel filter and see if that helps. Also a common problem is the wireing harness under the VC will sometimes come loose.
Get the recall done first, you never know.
EDIT: Where are my maners. Welcome to FTE.
I never had a 7.3, but both of my 6.0's had an engine service light come on, and that meant you need to drain the water from your fuel filter. On a 6.0 the fuel filter was under the driver, mounted inside the frame. You needed an allen wrench with my first 6.0 and I believe a little bigger allen wrench with my 2005. If you are hands on, you can check it, or if going to a garage, I am sure they will check it out. Good luck, and welcome to FTE.
Thanks for the help.
