hard to start when warm
Old Mar 2, 2008 | 07:48 PM
bobcf's Avatar
bobcf
88 f250 with a 460
When i do start and stop the starter turns slow like a dead battery. acts fine any other time. It is worse in the summer. I have changed a lot of parts, none have helped.
Thanks
Old Mar 3, 2008 | 09:25 AM
Conanski's Avatar
Conanski
Clean the battery terminals and engine and chassis grounds.
How's the fuel milage? If the motor is running rich it will wash the oil from the cylinder walls and make warm starts harder.
Old Mar 3, 2008 | 04:18 PM
bobcf's Avatar
bobcf
Not sure of milage, but often smells rich. Were should i start to see if it is running ritch, and how do I corect it?
Thank you for the responce
Old Mar 3, 2008 | 04:58 PM
cadunkle's Avatar
cadunkle
If it's carbureted (I know the larger engines had carbs longer than the small ones) I'd check for fuel dripping down the carb after you shut it off. Other than that clean all battery connections and grounds. Any reason to suspect heat soak in the starter? Headers? Exhaust really close to starter? If so try making a heat shield for the starter.
Old Mar 3, 2008 | 05:33 PM
bobcf's Avatar
bobcf
fuel injected, No headers. I though of a heat shield, Ill wrap the pipe that is close to the starter.......soon.
Thanks
Old Mar 3, 2008 | 05:41 PM
quicklook2's Avatar
quicklook2
conanski has the right ideas, battery cables checked for corrosion and good connection, both ends and same thing for any ground cables.
Old Mar 3, 2008 | 05:52 PM
fmr9's Avatar
fmr9
I had the same trouble with my truck. Cold it started fine, but hot it cranked real slow or would not crank. Changed the starter and problem disapeared.
Good luck Frank
Old Mar 3, 2008 | 06:32 PM
capt8ball's Avatar
capt8ball
my brother has an 87 mustang with a similar problem, a high-torque starter or replacing the stock starter would be a good start
Old Mar 3, 2008 | 06:58 PM
bobcf's Avatar
bobcf
I have thought about High torque starter. If every thing cheecks out ok I will try that. I can barrow the one from my 92 for a test.
I all so thought of a ground to the starter.
thanks
Old Mar 3, 2008 | 06:59 PM
DJdemon6696's Avatar
DJdemon6696
just take out the starter.. give it a "tune up" change the brushes and clean it and clean all your grounds you will be fine..
hkelley
Jun 27, 2015 10:11 AM
perryg114
Modular V10 (6.8l)
Feb 1, 2015 09:01 AM
bamboo321
Sep 1, 2012 09:42 PM
ssnbdr75
Oct 13, 2011 06:33 AM
cgrobar
Nov 14, 2007 01:39 AM
