Loose front end.....Ball Joints?
Old Mar 2, 2008 | 07:30 PM
FrontierGI's Avatar
FrontierGI
Just replaced front left hub and all rotors and brake pads (really easy to do) to stop the shaking or more of a "looseness" on my (new to me) 2000 7.3 X. I was feeling a looseness or a slight rattle, not really a clunk, but it mainly felt and still does feel like something in the front end is loose, mainly over rough roads and bumps. The mechanic said it was the hub, which was bad and replaced, but it still has that same feeling of looseness in the front end. It can be heard faintly and mainly felt in your feet on the floor of the X on the bumpy or not perfectly smooth roads. When traveling very slow and turning the steering wheel back and forth, the "clunk can be heard noticeablly in the front driver side area. I've read as much as I can and it seems to be either the ball joints or a sway bar bushing?
Any ideas or suggestions on how to narrow the cause without paying the mechanic to just look at it again (which they already did and said it was the hub)
Also, I will be out of town for the next two weeks and my girlfriend's mom, cousin, sister and aunt are all coming to Denver and they will be taking the X up to the mountains.......is this problem an immediate concern, or something that can have a few hundred more miles put on before being delt with?
5 women, stuck on I-70 in a snowstorm.....while possibly quite entertaining, is not the ideal situation for some out of town suburban ladies!
Thanks to all who look and help!
Old Mar 2, 2008 | 07:33 PM
FrontierGI's Avatar
FrontierGI
Oh, and the truck has 117,000 miles and I know the pass front ball joints have been replaced,
Thanks
Old Mar 2, 2008 | 09:10 PM
Btravelen's Avatar
Btravelen
Likely. Ball joints are a real problem on the Exc. and SuperDuty.
Take Care
Old Mar 2, 2008 | 10:22 PM
dizzy d's Avatar
dizzy d
I had a similar issue when I would turn or go over a bump I could hear a clunk and feel it in the floor. I just got under the truck with my torque wrench and hit every bolt in the steering and suspension I found a couple loose bolts in the steering. I would just go through it all there’s not a lot under there with a 4X4 it will only take 20 minutes or so. I wouldn’t let my girlfriend take a trip in a unsafe truck that is the last thing you need on your mind the hole time she is gone! Good luck!
Old Mar 2, 2008 | 11:04 PM
FrontierGI's Avatar
FrontierGI
Thanks man, I will take a look at that. Did that fix the problem?
Old Mar 2, 2008 | 11:06 PM
i eat hybrids's Avatar
i eat hybrids
Does the steering when you turn the truck? If it does, then its ur Ball joints
Old Mar 2, 2008 | 11:38 PM
dizzy d's Avatar
dizzy d
Yes it did.
Old Mar 2, 2008 | 11:43 PM
dizzy d's Avatar
dizzy d
Any time!!!
Old Mar 3, 2008 | 11:12 AM
JCoulter's Avatar
JCoulter
I have been having the exact same issue with my 2002 X.
It is primarily when I turn left and is coming from the front left wheel area. I will take a look at the ball joints and see if anything in that area is loose.
Old Mar 4, 2008 | 09:02 AM
FrontierGI's Avatar
FrontierGI
Thanks JCoulter, I let me know if you find anything and I will let you know too. I am hopefully going to get under it today to take a look.
Old Mar 10, 2008 | 11:03 AM
JCoulter's Avatar
JCoulter
I ordered up the new ball joints and (if they arrive in time) will be installing them on Saturday. I will let you know how it goes.
Old Mar 10, 2008 | 11:11 AM
i eat hybrids
JC what kind did you get?
Old Mar 10, 2008 | 11:26 AM
JCoulter's Avatar
JCoulter
I ordered the MOOG set from powerstrokeshop.com
http://catalog.powerstrokeshop.com/p...&siteid=214083
Old Mar 10, 2008 | 11:45 AM
i eat hybrids
Thats what i have, the moog greaseables. Great pick! Ull be very happy with them and they last alot longer.
Old Mar 10, 2008 | 11:52 AM
JCoulter's Avatar
JCoulter
I am pretty happy with the stockers that are on there... they last 120K miles, but I hear that is pretty rare
I only hope these do as well.
