So my truck has the K&N air filter
Originally Posted by tjbeggs
The K+N FIPK are much better than the drop in's but still not the best IMO. The AFE's are a good filter. I personally don't like oiled filters. I like paper much better. But the AFE is designed for diesels with a finer cloth from what I understand.
Nothing against you WALJON, but I have run my AFE for several years and the last time I checked I didn't see any abnormal wear... I have noticed that you definately need to be sure your clamps and fittings are tight however, otherwise you definately will spring an intake leak which is, well, like not even having a filter...
Group: Diesel Addict
Posts: 302 The following is the complete test results. In order of rank from BEST performance to WORST in the categories of FILTERING EFFICIENCY, FLOW RESTRICTION, DIRT HOLDING CAPACITY and TOTAL DIRT PASSING THE FILTER DURING TEST.
SPICER wrote:
In the order of filtering efficiency the results are:
FILTER % Efficiency
AC Delco OE 99.93%
Baldwin 99.72%
No name filter (made for gas engine, 1/3 less pleats) 99.32%
AFE ProGuard 7 (73-10062), panel filter 99.23%
WIX/Napa 99.03%
Purolator 98.73%
Amsoil, new style 98.63%
UNI 97.93%
K&N 96.80%
FLOW RESTRICTION FROM BEST TO WORST:
FILTER RESTRICTION in Inches H2O
K&N 4.54
Mystery bargain filter 4.78
AFE Pro Guard 7 Panel 4.99
Purolator 5.05
WIX/Napa 5.06
UNI 5.40
Baldwin 5.71
Amsoil 5.88
AC Delco 6.23
TOTAL DIRT PASSING THE FILTER DURING THE TEST. This is how much dirt your engine will take in if you use the filter for the duration that would cause the filter to become "dirty" enough to need replacement or cleaning. The "Dirt Passing The Filter" is the dirt collected by the "Post Filter" during the test.
FILTER DIRT IN GRAMS PASSED
AC Delco 0.4 g
Baldwin 1.1g
AFE Pro Guard 7 1.8g
Mystery Bargain 2.4g
Amsoil 2.7g
WIX/Napa 4.4g
Purolator 5.0g
K&N 6.0g
UNI 7.9g
FILTER % Efficiency
AC Delco OE 99.93%
Baldwin 99.72%
WIX/Napa 99.03%
Purolator 98.73%
UNI 97.93%
K&N 96.80%
K&N 4.54
Purolator 5.05
WIX/Napa 5.06
UNI 5.40
Baldwin 5.71
Amsoil 5.88
AC Delco 6.23
AC Delco 0.4 g
Baldwin 1.1g
Amsoil 2.7g
WIX/Napa 4.4g
Purolator 5.0g
K&N 6.0g
UNI 7.9g
I agree about the clamps and I assure you the clamps were always tight maybe we drive in different conditions or something but check it out AFE and K&N are the same element there is no special diesel filter element and from what I seen on my turbo is enough proof for me that this filter element lets lots go by
I too had a hard time believing this because of the price I paid for the AFE and no disrespect too you either everyone has there own opinion
hotgeo
17
08-30-2011 10:10 PM
