Programmer that accounts for other add-ons?
on
I've got another question, will the sniper software allow you to tune the FICM? The guy that I have been talking about just was able to do his own software that allowed him to tune that as well as his normal custom tuning. We spent about an 1 hr and a half testing and tuning after I got the new turbo on.
I don't know what your/he's working with in the fuel injection control module. I have the gas program only, but I can adjust for return or returnless fuel pressure, injector size, MAF calibration and location, low/mid/high fuel mod, low/high/rpm spark mod, and global spark and fuel modifiers, along with other features.
on
I have the sniper as well. Started with the special forces and upgraded to the Delta force. I have way more control of things than anyone ever needs. lol One nicety for the 98 was to control up AND downshifts along with torque convertor lockup & unlock. Changing from 3.55 to 4.56s threw that all out. Had to do manually sonce onl 99 and newer can adjust electronically. The best change was to remove the torque control feature. Watching the timing pull back to 0 to -5 (yes ATDC) during shifts made much sense to the trans behaviour.
But there datalogger need a lot of work...
on
The reason I mentioned it is because with a too lean tune you may think it drives just fine, all the while a valve is slowly being burned, or you hole a piston on a hot day when the engine momentarily spikes lean (which happens all the time since the stock O2 sensors aren't terribly accurate).
Originally Posted by broncoholic
I've read the excal II is a popular choice for these trucks. I see Troyer does custom tuning based your personal preferences and vehicle modifications. I guess this would be what I'm looking for. Thanks Alot
Spool&Go
01-17-2017 10:49 AM
TheBludgeon
13
05-24-2013 02:14 PM
