Rear end lube, what kind???
Ok guys as you have figured out I have been doing a rear brake job today. I found that my left rear seal was leaking and I am going to replace it in the morning. So tonight I pulled the rear end cover to let the fliud drain and refill it with new fluid...
So heres the question of the day.
What kind??? Brand, Mobil One, Amsoil, Royal Purple, someone else brand??
And how much do I need???
Thanks Doc.
Thanks Doc.
I used RP and it was right about 3 qts. Make sure to clean the VSS on the top of the pumpkin while you are there. Makes a good fill hole too.
I would give you the exact amount from the manual but it is in my truck. I used less as I still must have had some in the axle tubes. Yours may need more with the seal replacement.
Rear end holds 7 pints (3.5 qts) of 75W/140 syn. Use your favorite flavor. Don't forget a bottle of friction modifier if you have LS...
Guzzle's diff write-up:
http://guzzle.rbmicro.com/rdiff.html
[QUOTE=Izzy351]Rear end holds 7 pints (3.5 qts) of 75W/140 syn. Use your favorite flavor. Don't forget a bottle of friction modifier if you have LS...
http://guzzle.rbmicro.com/rdiff.html[/QUOTE]
Hey, grab the tag number and call a shop... there are different rear ends with different requirments. I had went to change tthe fluid in mine, and found out I had the "Heavy Duty" rear end. Which yeah, was the 75w/140, but what if it wasnt?
[QUOTE=just another truck]
He's got a 250 (SRW, obviously) which should be the Sterling 10.5 inch (which takes the 7 pints of syn 75W-140). Some 350s and 450s got the Dana 80, and the 550s got the Dana 135. It's still good to check, but I'm 99.9% I'm correct on this one...
Originally Posted by rustydailey
I plan on changing mine this weekend. I bought the Royal Purple, do I still need to add the friction modifier? If so how much do I add, I have the tube that they sell at the parts store?
