Is there a transmission difference?
All E4ODs have pans without drain plugs.
All 4R100s have drain plugs.
Ford does not make the E4OD pans anymore and all part #s are replaced with 4R100 part #s. When you go to ford and order a E4OD pan you are getting a SD 4R100 pan. If you 97 older truck has a drain plug then the pan was replaced.
on
I have a 98 f150 4x4. Its not a 99, because it has a 97-98 bumper front and non-pi 5.4.
So, now what do i have here? I bought it used in y2k w/ 32k miles
cnacowboy
07-23-2010 10:00 AM
napalm00
06-03-2010 04:01 PM
