oil in the intake
That oil came from the crankcase ventilation system. If you look at the left driver's side valve cover you will see a short hose that connects to your intake tube. Oily gasses flow from that tube into your intake tract and make their way through the system. That is why your IC boots get that oily gunk on them.
Doing a "CCV mod" will remedy this problem.
The CCV mod.
A lot of guys build their own. I used this kit. Click the link, it explains what it does for you.
http://www.itpdiesel.com/store.php?c...on=show_detail
on
Here is some more info... (see CCV) http://www.7point3.com/mods.aspx (bookmark this).
You will notice that your turbo tubings are probably leaking oil vapors and getting your engine dirty.. Doing the CCV mod eliminates this...and will keep your intercooler clean.
