Tow Hitch how High ?
Old Feb 25, 2008 | 12:15 AM
Darrell Maryland's Avatar
Darrell Maryland
I am make a custom hitch plate how high off the ground should it be ? how high
Old Feb 25, 2008 | 01:29 AM
LastSplash's Avatar
LastSplash
The easiest way is to fabricate the hitchplate with a 2" reciever and buy a drop hitch that will allow the trailer to be level when attached.
Old Feb 25, 2008 | 12:21 PM
Darrell Maryland
i measured a uhaul truck and it was 18 inch off the ground is that the standard . I don't want to scrap the ground when leaving parking lots .
Old Feb 25, 2008 | 01:07 PM
nelstone74's Avatar
nelstone74
I just measured mine it is 20" high I have thought since about 5 minutes after i built it it was too high. See the drop I need to hook to the trailer. I think tha 15.5 would be fine. I don't think I have ever drug the tongue of my trailer in a parking lot and it is loer than 15 inches.
Old Feb 26, 2008 | 10:33 AM
SUPERJADE77's Avatar
SUPERJADE77
Are you hauling the same trailer or different trailers? If the same one always measure the distance from the ground to the top of the trailer frame rails between the tires. This should be the height of the top of the ball. If different trailers then weld up a hitch receiver and use different drop stingers.
Old Feb 26, 2008 | 03:00 PM
tim.moman's Avatar
tim.moman
18 inches is standard height. it looks to me that you are right in the ballpark
rla337
Sep 1, 2024 01:50 PM
Gufunk
Feb 17, 2012 09:39 AM
Skyline Drive
Feb 14, 2012 08:43 AM
Skyline Drive
18
Dec 5, 2011 11:16 AM
DougB442
Modular V10 (6.8l)
Sep 22, 2002 09:56 PM
