hutch / harpoon mod ??
Hey guy's, I'm new to this site and you guy's helped me out already with the foil delete mod ( which is great ) but my question now is , what is the hutch and the harpoon mod ?? I tried to search it but for some reason I can't find anything ? thanks again for all your help with this great site !!!
Go here:
http://guzzle.rbmicro.com/hutch.html
EDIT: And welcome to FTE!!! Glad you're enjoying the foil delete. You can remove the "hutch.html" part and read about some other mods guzzle has written up. Or, if you REALLLLLLY want to get bitten by the PMS (PowerStroke Modification Syndrome) bug, go here:
http://www.7point3.com/Mods.aspx
Harpoon is basically cutting the vent tube in order to speed up the filling process.
Harpoon mod is located here:
http://65.121.190.196/diesel/intank/
The Hutch mod is here:
http://community.webshots.com/album/32614313yLKyrS/1
The Hutch mod is to improve the in tank filtering and I have not seen a write up on it, though I am sure there probably is one.
You can get all this info and more from reading the links here:http://www.7point3.com/mods.aspx
Lots to learn.
Lots to learn.
Yeah, I did buy the ITP kit. Thanks for bringing it up -- it's definitely the easy way to get everything you need in one shot, plus very good instructions. Just watch that ring on top -- it can cause problems if you get it cross-threaded or not tight enough. That's what happened to me, but it's fine now.
Originally Posted by 9299Fords
ITP site still says parts not available. Anyone check this out with them recently? I'd like to buy this kit and get 'er installed.
For the filter I am going to go with an el cheapo inline for now. When I do the DFA reg return I will upgrade.
