Hello,
I bought a 97 Motorhome last week, 7.5l gasser with E4od, and the tranny and cruise are not working right. First I noticed that when cruise is on and I turn on my blinker or hazards, the thing comes off cruise. Also the tranny downshifts out of OD and also 4th to 3rd when I touch the brakes, use the turn signals or the hazards. Sometimes it will not do it when using the right turn signal. I tried it with the OD button in off and it will still downshift. Since I have no idea of anything that has been done to the Motorhome, I am in a bind. It does have a transcommand that I unhooked just to check that that wasnt the problem. Any ideas or comments!!!
Thanks
I was thinking it has a short in it somewhere too.
I pulled both fuses for hazard and turn, but it still does it. The brake and turn bulbs work, but sometimes the right one doesnt. I may tear into the steering column and see what I can find. Still looking for answers.
Thanks
I pulled brake fuses and still does it. It does not downshift when the throttle is say half or better. Maybe it the TPS..???
I was hoping that someone had ran into this before...
Thanks
