Engine Light no throttle response F350
Bought my 02 last year used.. About a month later, lt used to just be ln the morning truck would start, no response with throttle. Engages ln gears but won't move.. Now lt's dolng lt regardless of weather. Thls afternoon l went out to leave and had to slt 20, may be a coincidence. but l wiggled behind the gas peddle some sort of linkage and engine light went off and ran. Got 3 miles down the road dld lt agaln. Didn't wlggle cable put lt ln Neutral, to coast off road. Dropped lt ln drlve and lt drove agaln.. Then lt happened agaln. before lt only would only do thls once ln a while ln the cold mornlngs. Transmission, shop sald lt was a throttle control sensor. Does thls have to do wlth the recall or had anyone else had thls problem. Thanks.
Welcome to FTE. It does sound like a problem with your throttle position sensor. That's the thing on the go pedal with the wires you jiggled. You can check the wires for any pinches or chaffing, unplug, clean, and replug the wires back in. Even remove the sensor off the pedal to inspect, clean, and make sure it's mounted properly. You may end up just having to replace the sensor.
moved the 4 wlres under fender and not a slngle problem thls a.m. Changed out my shockes over the weekend and mlght have bumped that group of wlres.. saw a post on here that looked slmular about have a slm. problem after a raln or wash.. hopefully that's the extent of lt. Thanks for the help, thls slte ls really a lot of help!
