Cab Mount Change over
I am in the process of changing out the cab on my 77 Highboy. I purchased a 75 150 2x4 for a donor truck. I have already removed the bed and started doing the body work on that. I have already swapped most of the interior over - steering column, floor pans cut to accept the 4wd lever and 4spd. shifter etc.. The old cab mount cradles are in poor condition and I will be replacing the bushings on the truck when the swap is complete. I was wondering if the donor truck's mount cradles would work or do I need to repair the old ones? They appear to look the same but I have not removed them yet to verify it.
crazyredneckanyhow
09-23-2007 06:50 PM
