wheel spacers on a F350?
I looked at some threads on here that say stay away from wheel spacers. But then I found that its better if you get hubcentric spacers. I have a 95 F350 crew cab Diesel 8 lug by 6.5. I am alittle worried about all this weight on spacers. Has anyone put spacers on there truck and had any problems? If so where did you get them and how wide. I see that the rear studs are 2 inch and about .100 thousands long so 2" spacers wouldn't be enough.
on
I would not want to run 2 inch spacers all the way around. I MIGHT run 2 inch spacers on the rear to bring the rear tires out in line with the front tires. You might have to trim a little off the end of the studs though. I don't tow any real weight so that would not worry me but it you tow heavy I wouldn't run spacers at all.
i would get different wheels if you want to change the stance of the truck, by adding only spacers you are using the same footprint of the wheel and moving it outwards. this puts additional strain on the wheel lugs and bearings as well as balljoints.
if you get a wider rim with a different offset this will give you the wider stance you desire and wont be nearly as hard on the truck. it will also look 10 times better too
on
Originally Posted by 8inav
wheel spacers are a bad idea in my opinion, hubs and wheels are designed to clamp together. lug nuts are only designed to hold 10% of the vehicle, the center hub holds the other 90%. also the front tires will ware really bad on the inside because of the alignment
on
spacers would screw with SAI tho wouldent it?
on
gotcha gotcha, i am still learning, the only reasion i was considering SAI was a friend of mine had some offset rims on his truck and they would wear like crazy. thanks for the info.
1978fordf250
04-22-2008 09:17 PM
