end links, bushings, & 6637 on!!
I just finished installing my new sway bar end links, sway bar bushings, and 6637 filter. Went for a little drive. The front end seems a little tighter, not as much slop in the steering. There is still something making a thump on the driver's side. Everything feels tight when I jack the tire off the ground. I haven't checked the shock though. I didn't really notice much difference in the sound with the 6637. When I bought the truck it had a drop-in K&N, which we all know (or at least here on FTE) is not good. Here is the kicker. When I started removing the filter box, a piece came off in my hand. It appeared that it had been glued on. Then, I decided to remove the intake pipe from the ccv to the turbo so I could wipe out the inside. What the, the clamp at the turbo was just hanging on the pipe. It wasn't even close to tight! I checked for any movement in the wheel on the turbo and everything feels really tight. So I cleaned everything and put it all together. THANK YOU ALL for the knowledge I have gained on here!! Next up, filter cover from you know who and the S/S HPX line. Maybe someone on here has a S/S HPX line that they want to sell?
WOW.....it sounds like you got extremmmely lucky that you didn't dust your turbo with everything that loose! Did you have any pitting on the wheel at all? Being sorta dirty is to be expected with CCV in stock form, but nothing "severe" I also went from a "drop in" K & N filter...but I noticed a HUGE difference in sound and power on the very first drive with the 6637. You should be getting the normal "whoosh" sounds that the 6637 is known for......
I think that there seems to be more power, or at least a little more responsive. I can't really hear it over the engine noise, especially when it hasn't warmed up yet. After a little more drive time I'm sure I'll notice. I can't determine why the engine noise is so loud when it isn't completely warmed up. It kinda sounds like an exhaust leak and I'm thinking it's the up-pipes. I can see a little soot on the driver's side. After I drive for a while it quiets down. Maybe when the pipes warm up they seal a little better, i don't know. Just real glad to get it done!
Take a look at your leaf spring insulators, and the leaf spring eye bushings at the shackle. I've started getting a thump from there too in the last week. There was a TSB a long time ago on the insulators, but I have a feeling that mine is the bushing at the shackle from the feel of it. I'm doing an oil change and tranny fluid service on it tomorrow. I'll post back what I find.
Austin
Austin
Good idea Chris. I think I'll get some simple green, get up under the hood, really check everything for tightness, and then spray her down and clean this beast! I do feel fortunate that I found these problems now. The wheel on the turbo doesn't appear to have been damaged judging from the pics I saw on here. I do have a feeling that the up-pipes are going to be a job I'd rather not have to do. I need to look into the bellowed ones that everyone talks about.
Austin, I'll look at the spring isolators. I remember looking at that TSB prior to doing the end links. I wrote down the part # for the "updated kit" from Ford. I think I'll try that too. Thanks to all!!
I tried to pm you but the system wouldn't let me. Here you go: The user id is boxrugs. He had previously listed a set and someone beat me to the buy it now. I e-mailed him through ebay and he contacted me for my vehicle info. He had a set in about a week. Set up a buy it now for me. Real good transaction. Let me know if you need any assistance and I'll try to help any way I can.
Check your settings on your profile. Make sure you have checked to send/receive pm's.
f350vince, that's what I was going to do, but I really didn't have the proper tools to get the old bushings out of the end links. Everyone says it is difficult, so I bought new end links and the two bushings on the sway bar itself. I would have rather had the poly bushings, but sometimes things don't work in my favor. I am saving my old end links so at some point I might be able to remove the old bushings.
http://www.energysuspensionparts.com/
