New to Gooseneck Trailers Question
I've no idea how I would search for this so I'm posting w/o searching. If there is another thread here then tell me. I've towed a lot with tag trailers but am looking to move into bigger trucks and equipment.
In my perfect world I could tow a GN trailer with two pieces of equipment on it that total to approx. 12,000 lbs.-the length would be about 15-17' on the GN flat section with the tail at least 5 feet additional. This puts me at a 20' long trailer. In the tag trailer world you deduct the trailer "running weight" from the GVWR, I assume that this is the same for GN trailers. That would mean if I found a GN trailer that weighed 5500 lbs.(running weight) then the trailer would have to have a GVWR of at least 9-10 tons to carry the load.
Here's the question part: Is the GN truck king pin weight of 20-25% based on the total weight of the trailer running weight + plus the equipment or just the equipment?
Here are the scenarios:
King pin weight based on the total combined 8-9 tons, i.e at least 3600 lbs. at 20% of 18,000
OR
King pin weight based on the equipment weight of 12,000 lbs., i.e. at least 2,400 lbs. (20% of 12,000).
Thanks.
OR
Thanks.
Your pin weight is based on the loaded trailer. How you load the equipment can affect the balance of the trailer. For instance if you have a pickup on the trailer nose first, there will be more pin weight than if you put the bed first (and the heavier front over or behind the trailer axles). Note also that your pin weight takes up that amount of the available payload of your truck.
Jason
Jason
Plan on 20-30% of the LOADED weight of the trailer... with a 20,000lb trailer that'd be 4,000 to 6,000lbs on the truck itself, like mentioned, depending on how its loaded. Less than 4000lbs on the truck can lead to problems, so make sure you don't load poorly and make the tongue TOO light.
Ok. If its the loaded trailer then its the combined weight of trailer weight and equipment-then in this scenario you would need an F350 DRW with a payload capability of at least 4-6,000 lbs. A loaded trailer here would be 12,000 equipment plus trailer at 5,500 lbs. to equal 17,500.
The 2008's in the 4WD F350 DRW handles 5,380 lbs. payload at max.
So here's the next question. How do I see other contractors pulling a 15,000 lbs. backhoe on a 20 ton 20'+ trailer with an F350 DRW? The king pin weight is well beyond the max payload for the truck let alone the GCWR of the trailer and load. We are talking 30,000+ lbs. Are they just making a choice to tow "heavy" with the risks or are they just, ahem, "unaware" of what they are doing?
Read the other posts on the top of the towing page... Manufacturer's GCWR are not legal definitions. Legal limits are defined by the amount of money you pay the DMV. Even though those trucks SHOULDN'T be towing that much, they can if they have proper tires (but not axles? brakes? etc?) and proper registration papers. In that concept, the GCWR is the total of the truck's GVW and the trailer's GVW. The truck must be plated for an amount greater than the GCWR. Makes no sense to me.
Ummm yeah, in some states you can apparently "buy" your way to more capacity at the DMV/BMV desk and having a nice chat with Betty behind the table!
I am sure there are all kinds of formulas but I watch where the front axle is on the trailer and then how much weight the truck takes, i.e. how much it starts to settle. Once I see the truck taking some weight and feel comfortable where the load is in comparison to the front trailer axle I call it good. You want the truck to take some weight so it won't fishtail all over the place and still have as much weight as possible over the trailer axles.
I'd love to find these states that allow you to "buy" your GVW, here they take the trailer and truck ratings and you better not be over what is listed on the manufacturers plates, they also use that for what license you need to be pulling the load.
Just because you are registered for more wieght doesnt mean you dont have to have the additional axles to support it.
Funny thing, in the manual an F250 and an F350 have the exact same GCW. So whats up? There are loop holes in all the states rules.
Originally Posted by icrman
In your state, what if, a person puts components from a heavier truck in himself? Then he becomes the manufacture. Like putting F450 axles in an F250.
jeffdoerr
06-02-2010 10:41 PM
captain p4
Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion
25
07-26-2007 09:55 AM
Jigsawrx7
Flatbed, Car, Boat, Utility, Horse & Misc. Trailer Towing
13
12-15-2004 11:33 PM
