The following are the Ford part numbers for the parts you need, assuming you have a late-build 2004 6.0L (with a vehicle build date later than September 29th, 2003).
4C3Z- 9A543-AARM High Pressure Oil Pump
3C3Z-9C968-AA (CM-5054) IPR Valve
Originally Posted by tcjhkbjt
thanks, my ICP is on the passenger side valve cover if that also helps.
If your ICP is on the passenger side valve cover it is a late 04 model, Mchan gave you the part numbers for the late 04 model.
