83 non-HO 351W cam, add 1.7 or New Cam
Ok, I know the specs for the 84- HO cam, and the lift of the 83 non-HO cam, but not the rest of the specs. Anyone know?
I figure I could probably stick on a set of 1.7s and get the lift, rather than have to pull apart the thing and stick an HO cam (Or Comp Cam, Crane, etc).
A. Non-HO Specs?
B. Can the Springs take the 1.7s lift?
C. How much can I add without having Banana Valves on the stock 83 pistons?
Thanks, guys!
A. Non-HO Specs?
Thanks, guys!
on
The non-HO cam is no more than 0.416" lift at the valve with 1.6 rockers, 1.7 rockers would give you 0.442" lift... no bad for the amount of work involved. The springs can take that much no problem, and I don't see any issues with valve clearance considering the short duration that stock cam has.. it's no more than 260 deg advertised, probably closer to 250 degrees.
on
Originally Posted by 96sherm
worth the little effort of the swap??
summitracing.com has them, or just about any speed shop. http://store.summitracing.com/egnsea...115+4294925044
