it seems quite often now that wheni start my truck up, i get exhaust smell inside the cab, not sure if this is normal (highly dout it) but wondering what would cause this? i have the drivers side up pipe leaking, could that be my problem?
Leaky up-pipes can definately cause an exhaust smell in the cab. Since the intake for the climate control system is in the wiper cowl, it's pretty easy for an exhaust leak in the engine bay to find it's way into the cab.
My pass. side up pipe is leaking and I have exhaust smell in the cab whenever the truck is stopped. I can see soot around the upper squash coupling. New donuts and a lot of elbow grease is in the works for this spring.
