1995 7.0 F700 429 OIL PAN
I have a 1995 ford f-700 with a 7.0 motor the oil pan is rusted and leaking beyond repair Vin code has J in and that seems to kick me out of any part numbers or availability, Are there other apps that use the same pan. This pan does have the dipstick mounting on the pass side. any ideas/help is appreciated
Welcome to FTE!
Your pan look like this?
https://www.autozone.com/external-en...-pan/ford/f700
370 and 429 in medium trucks should have the same pan.
Some aftermarket pans might work if you can't find a stocker.
