engine swap 460 carb. for a 460 EFI
Old 01-15-2000, 11:05 PM
Rich's Avatar
Rich
Rich is offline
I have an 86 f250 4x4 with a 460 & C6 trans with 172,000 on the engine, the body and running gear are good but the engine is tired. I was wondering if anyone had any info, comments, or suggestions on swaping in a 87-90's EFI 460.
Any help would be appreciated.
Old 01-30-2000, 09:41 AM
BOE's Avatar
BOE
BOE is offline
HELLO....YES THE ENGINE WILL FIT BUT ITS THE WIRING THAT WILL MAKE YOU PUT A CARB ON THE ENGINE. I JUST DID IT ON MY 87 F350. I USED THE MOTORSPORT WIRING HARNESS FROM A MUSTANG USING THE COBRA KIT THEN I HAD TO REPROGRAM THE CONTROL UNIT WITH A LAP TOP ...GOOD LUCK BOE
Old 07-05-2000, 05:03 PM
shami02's Avatar
shami02
shami02 is offline
How and where did you get information on reprogramming the mustang control unit with your laptop? I want to find out all I can about the process, I can't find a manufacturer of a reprogrammer for my '95 460 E40D.... Folks sell chips but no reprogrammers..... I want to be able to tune the truck for the type of use taht day! If you knpoe what I mean...
Thankx in advance for any help you can provide.
Mike Shaffer
Old 07-11-2000, 11:32 PM
Huggy Bear's Avatar
Huggy Bear
Huggy Bear is offline
EvinrudeDude300
21
04-14-2024 07:13 PM
pm042070
01-31-2015 05:08 PM
paulm
Oil & Lubrication
02-03-2014 09:00 AM
97puller
09-06-2013 10:41 PM
Quick Reply: engine swap 460 carb. for a 460 EFI
