77 350 plastic rear tank
Help!
77 F350 Custom has a plastic rear gas tank (about 15 x 15 x24). Metal skid plate on bottom.
Sender in the middle on the front side, fill tub middle rear side.
I think the part number is D3TZ9002V. Can't find one.
Tank leaking at the filler to tank connection.
Any suggestions besides JB Weld?
Thanks, Tom
Thanks, Tom
I've got two 79 F350s with that same tank. The other day I had a truck here at work up on the lift. It was a 94 F350 4wd cab/chassis with a dump body and it had what looked from underneath to be the same tank/skid plate arrangement. I didn't look at the filler neck arrangement so I can't be sure of that but the skid plate sure looked familiar.
