Fuel Filter Doesnt Want to Come Out
Picked up a new fuel filter at NAPA yesterday, and went to change it today. Of course its 20 below and a howling wind but hey, i love my powerstroke. Thought it was gonna be a quick, easy job, so i popped the cap off and went to slip the old one out but it didnt want to budge. I havnt changed the powerstrokes before. Am i missin something? Or is it just my lucky day? Sorry for the stupid question, but i dont wanna go reefing on it and break something cause i had a brain fart and forgot something.
If you bought your filter at napa.You have to get the lid{$10}from them also.Your truck came with that two piece filter design.Somewhere along the way someone put a one piece filter and lid combo on.You get them at cetain other parts stores.They say the original design{two piece] is best.so just get a new lid and you;ll be set.
on
1 Post
If your lid came right off there should be nothing to removing the filter element. 20 below zero and you're doing this? Are you crazy? Can't you just get your finger in there and wiggle it around? I have never seen or heard of this before. Try some needle nose pliers and just pull up on it. Mystery to me.
The filter i got at NAPA looks exactly the same from what i can tell. The one from NAPA also looks like the two piece. Outter shell and then the inner filter. The lid comes off fine, but then the filter is in there really stiff. I thought the o ring as well but wasnt postive. Thought i might be forgetting something.
Originally Posted by poppie
Might have a small amt of water in the bottom of the bowl that's frozen,you said -20 degree's,holding the filter down
When you get it to the shop crawl under the truck and onthe front of the engine pass.side you will see a steel line or tube that just ends thats your drain tube for your fuel filter. Get a piece of hose and slide on it long enough you can drain it into something then open the drain valve on the filter canister the yellow handle on the pass side and you can drain the fuel out.
I let in run on high idle for a bit and drove around afterwards to get it good and warm. Pulled it in my shack behind the tractor, and it popped out quite easy. Drained and flushed out the bowl, went and fueled up and was generous with the conditioner, so hopefully that should help if there was any water in there.
Oh yeah, it helps to remember to shut that little valve too once your done. Wheres the stupid icon? Thanks again.
