fpr shim install
Instructions are in this link:
http://www.7point3.com/Mods.aspx
Fuel Pressure Regulator Shimming (under mods)
I shimmed mine and noticed a increase in power. Ford set the fuel pressure in the mid 50s psi on our trucks but International set the T444E (our engine) at the low 60s psi.
I have a fuel pressure gauge so I know where mine is running all the time. With the shim, I'm running 68 psi at idle and 64 psi at WOT. I noticed a huge difference right away.
