460 engine information
Old Feb 11, 2008 | 12:22 PM
masterbeavis's Avatar
masterbeavis
Does the vibration happen at road speeds, or certain RPM? We need more info to help you diagnose what your problem might be.
I have seen 460s that had huge weights welded onto the crank because of serious imbalance problems in the casting, that were corrected when the rotating assembly was professionally balanced.
Old Feb 11, 2008 | 01:30 PM
Andy B's Avatar
Andy B
ok... It comes in as soon as you give it some gas..Dont have to be driving. "Just sitting in the shop giving it gas and pondering. If you hold it down and just keep incressing in RPM's it will fade away at around 3000 to 3500 and as you keep on it will come back in. I have taken the belts off and had nothing pulling on it and still the same vibration. Pushed the clutch in and left in neutral... same problem. Does this help you?
papabills54
Nov 7, 2016 02:26 PM
Taylors68fastback
13
Oct 17, 2016 11:14 PM
Nick-1973-ford
Oct 6, 2016 04:19 PM
MotorCityBolt
2015 - 2020 F150
21
Mar 3, 2016 05:34 AM
TommyCroft
Jan 16, 2016 02:31 PM
