Heads
Heads
Sounds more like just plain ol' tired engine syndrome. The main bearings are worn which is causing your low oil pressure, the valve seals are probably shot which along with blowby past the rings is causing the oil consumption and blue smoke. If you had burned valves than you'd have low compression in 1 or more cylinders but not necessarily low oil pressure or blue smoke.
78 Ranger
01-28-2006 12:54 PM
FordPickup460
07-12-2004 03:14 PM
78broncoman
02-12-2004 09:55 AM
fordboy1973
05-28-2003 03:47 PM
