460 Head Question
Old 03-30-2001, 01:12 PM
stingrayj72's Avatar
stingrayj72
stingrayj72 is offline
460 Head Question
Old 04-04-2001, 12:33 PM
460hipo's Avatar
460hipo
460hipo is offline
460 Head Question
I have a set of D3VE-A2A heads that are in the shop now for a valve job (2.19 & 1.71 to be installed). The heads came out of a 1974 Lincoln.
2 questions - when I pulled them from the Lincoln, at the back of each head was a small pipe leading to a "T" that joined the heads. The pipes were pressed into the backs of the heads and came out easily. Since these are going into an older vehicle, should I just plug the holes?
#2 - Can I run a cam with about .503" lift with the standard fixed rockers (I will upgrade the springs)?
BTW - this board has been the best for 460 head advice, which I am following on my rebuild.
Old 04-04-2001, 12:50 PM
dre's Avatar
dre
dre is offline
460 Head Question
Yes you can just plug the holes, that's what I done to mine.
Yes you can use the .503" lift cam with stock rockers,
that's the same lift cam I am using.
Produced by SUMMIT RACING.
very nice cam.
Dre'
1978 F-150, 460ci(750cfm,Edelbrock Performer,Dynomax Ceramic Coated headers,etc.)Auto-C6,3:70.1 - 9" Posi.
Old 04-04-2001, 01:35 PM
460hipo's Avatar
460hipo
460hipo is offline
460 Head Question
Good guess - the Summit IS the cam I will put in, so it is good to hear a recommendation....also the Edelbrock 750 1407 carb will be used.
What do you recommend for a good deal on valve springs?
Old 04-04-2001, 02:21 PM
dre's Avatar
dre
dre is offline
460 Head Question
The Edelbrock Performer Springs are good.
although the stock springs(unless worn)are strong
enough for that cam.
Dre'
Old 04-04-2001, 06:05 PM
79supercab4x4's Avatar
79supercab4x4
79supercab4x4 is offline
460 Head Question
460hipo-
what all else are you doing to the engine othere than the cam? also, whats the duration on that cam? let us know what youve got and what its running like once you get it going. =)
Old 04-04-2001, 07:41 PM
460hipo's Avatar
460hipo
460hipo is offline
460 Head Question
The block is next to go to the shop to be bored .030 over. It is a '71. I will use the Summitt 460 rebuild kit with flat top hypereutectic pistons. Kit includes gaskets, pistons, rings, cam, lifters, oil pump, timing chain, all (main, rod, cam) bearings and freeze plugs for around $400 bucks. Meanwhile I'll be grinding the humps out of the exhaust ports this week.
Motor will be going into a Cobra kit car, so I really don't need anything very extreme in terms of power adders.
Right now I am considering the Stealth intake based on what i've read about it in comparisons.
Also, I have picked up a '76 electronic distributor - does anyone know if this is a good choice over the older ones?
Old 04-04-2001, 07:45 PM
460hipo's Avatar
460hipo
460hipo is offline
460 Head Question
Oh yeah, the cam is a 218/228 duration .503 lift with 114 lobe centerline.
Old 04-04-2001, 08:15 PM
mavman's Avatar
mavman
mavman is offline
460 Head Question
yep, the 76 model distributor is the same one I use. People knock them all the time, but I have two of them....one is on my '75 maverick 302, all the goodies (9.45 @ 137 mph 1/4), and the other is on my 83 f100, 514. I did remove one advance sping to help the advance curve come in sooner, but other than that, it's still stock. I wouldn't reccomend removing the spring on your particular application, unless you are running less than 8.5:1 compression. It can sometimes cause a pinging problem at low speeds, but when revved past 3500, it goes away. Hope this helps
Old 04-05-2001, 06:15 AM
460hipo's Avatar
460hipo
460hipo is offline
460 Head Question
Mavman,
Are you saying the 302 and "385" big block can use the same distributor? I probably should know this, but i hate to admit I know a lot more about chevy interchange than Ford, but there is less to learn on that side.
Old 04-07-2001, 07:02 PM
dezmoduo's Avatar
dezmoduo
dezmoduo is offline
460 Head Question
I just picked up the heads for my 460 (F250 SuperCamper/1986) after having the exhaust studs drilled. I'd been putting this work off for 2 years but the exhaust gasket was really breaking down.
I also have the holes to plug in the rear of the two heads. The port is unthreaded so whats my best bet in terms of a plug? I'd like to only have to do this while the heads are out.
Hedders are going to be mounted (Hedman). I hope this goes smoothly starting with the heads off.
Regards and thanks for any suggestions.
Gary
Old 04-07-2001, 09:10 PM
460hipo's Avatar
460hipo
460hipo is offline
460 Head Question
I talked to the machine shop and they said I could either press in a small plug (like the one on the other side of the head) or tap it and put in a threaded plug similar to the ones on the top of the head. I think I'll use the press-in. An auto parts store that carries a good supply of nuts-and-bolts hardware will carry the right size plug
04-13-2004 12:08 AM
11-12-2002 01:38 AM
01-14-2002 09:06 AM
03-11-2001 10:13 PM
Quick Reply: 460 Head Question
