351W swap to 460
Old 06-10-2001, 07:06 PM
460swap's Avatar
460swap
460swap is offline
351W swap to 460
What will I have to convert to go from a 351W with a c-6 auto to a 460. It is a 86 Ford f250 4x4. I want to know if I have to change trannies. I know I have to change motor mounts but the more info the better. Please help, it will be appreciated.
Old 06-10-2001, 08:44 PM
Ford79's Avatar
Ford79
Ford79 is offline
351W swap to 460
You will have to change the tranny. The easiest thing to do would be to find a truck just like yours in a wrecking yard with a 460 in it and you will have everything you need. If you can't find a donor truck, you will have to find a tranny, rear sump oil pan, truck manifolds or headers and a bigger radiator. You might also have to change the frame perches. Contact http://www.landlproducts.com or call them at (214) 475-5202 and they should be able to answer all your questions. Hope this helps.
Old 06-14-2001, 07:05 AM
DeenHylton's Avatar
DeenHylton
DeenHylton is offline
351W swap to 460
TheMechanicalAnimal
63
01-29-2019 07:39 PM
Fordman96
1978 - 1996 Big Bronco
30
04-16-2013 07:28 PM
blownz
02-25-2008 12:48 PM
lilboysdrivebowties
Engine Swaps
04-01-2004 11:14 PM
460swap
06-13-2001 09:28 AM
Quick Reply: 351W swap to 460
