salvaging my '04 F150 for '60 F100
Hi guys!!,..Thought I would share,..I recently rolled my "04 150 and destroyed it,..I also have a 1960 F100 short bed styleside.
I am planning on putting the 4.6 and trans. into the '60 and figure I will remove complete wiring loom and fuel tank plus abs system , remote door locks and window motors temp./ direction gauge and seats,..any advice,???and drive shaft and ford blue oval badges,...and of course computer.
How long did the engine stay upside down? You'll need to drain the oil, pull the plugs, and clean the engine out, so it doesn't throw a rod from trying to compress fluids that dripped into the cylinder. I did it with a 302 2 weeks after I rolled my truck. I thought I had it cleared, but guess not. Just erring on the side of caution. Otherwise, I say go for it.
Thanks HAVI,.....actually,...total upside down time was about 1 and 3/4 seconds,...(about 1/4 second for each of the 7 times it rolled) until it stopped right side up !!! sorry,...had to say it,...it really did roll 7 times,...I'm sure there will be many issues to address looking at it,...the engine is about 7 inches to the left off center in the engine compartment
Received 1,353 Likes
on
on
I would forget about the ABS system. ABS systems aren't very modifiable friendly. To would have a remote chance for it to work would require the front suspension and rear axle in the 1960. They also use special wires and if you mess with the resistance at all then it will throw a code and disable itself.
ojai150
02-12-2008 03:48 PM
