Anyone have a similar short, or can help me track it down?
Symptoms:
-Glowplugs, all but one checks out within norms of ohmmeter, that one reads infinite, tested the relay and it is good, but they are not warming the engine. I even swapped the relay out on a lark, no change.
-engine lopes/romps
-I have continuity from any positive terminal when disconnected from the batteries to any place on the engine.
-Truck will start when warm out
-ABS light is on at all times
-CEL light still comes one when I force a fault
-No other interior electric works besides TAC and overhead cab lamp.
-Headlights will work
-turn signals will not work
-brake lights will not work.
-Batteries would drain if left connected overnight
-power door locks will click the relay under the dash, but will not activate the actuators
-blower motor for HVAC not functioning
It is my theory that the glow plug system is being bypassed by the short, because of the significant resistance difference.
The thing that gets me, is that I can still start the truck and run it with this short in the system. Any ideas?
-engine lopes/romps
I am pretty sure that you should have continuity even witht he batteries unplugged. This comes rom the alt. I said pretty sure, so I could be wrong. If there was a short, I figured it would have popped the fuse, or melted a relay, unless one isnt working. So when you have everything shut down, is there something working that shouldnt be? I.E. can you still roll windows up, does your windshield wipers still work, etc....
Have you load tested the batteries? Is it possible that waht you think is a short killing your batteries is really just a few bad cells in a battery? Just food for thought.
on
1 Post
Originally Posted by iasrap
Symptoms:
-engine lopes/romps
-engine lopes/romps
If so YIKES!! Todd mentioned the alternator. I would unhook the charge wire at the alternator and see if you still have continuity.
Originally Posted by tjbeggs
Does this mean that with the batteries disconnected you have continuity to any part of the engine like the block, alternator case....
If removing the charge cable from the alternator solves it, does that mean my alternator diode is out?
on
1 Post
on
1 Post
Originally Posted by MADVAN
TJ
Iam in the dark. Missed the posts.
Confused. Cont to ground?
Bill
Bill
The more I think about this continuity thing the more I think its not really possible. You cables would burst into flames and the truck wouldn't start if both the neg and pos battery cables were grounded out. Tell us exactly how you are testing this please.
Bill this truck was completely submerged for over 30 minutes in a pond!! Who knows what we will find.
I wonder if as of now it has a batt draindown isssue in off condition.
WAG
Bill
I placed one lead of the continuity detector on the positive terminal cable with the batteries disconnected I then placed the other end on the alternator housing... "beeeeep" then i moved it to the HPOP "beeeep" then the block "beeep." Make sense?
I do not know what it means, but would suspect it is a short in the system because the batteries will get drainined over time if left hooked up, and I am no expert on electric theory, but I am pretty sure the block is not supposed to have connectivity with the + terminal connector unless the truck ignition is in the start or run position. Is that right?
