Choke?
Old Jan 29, 2008 | 11:29 AM
MER's Avatar
MER
Choke?
Where do you hook the end of the cable onto the carburetor on a manual choke on a 1 barrel any help would be much appreciated Thanks
Old Jan 29, 2008 | 03:32 PM
Harfend's Avatar
Harfend
Need a bit more info to help you out Bro.
Are you hooking up a manual choke conversion? Or are you wondering about the throttle cable?
Old Jan 29, 2008 | 03:38 PM
MER's Avatar
MER
The manual choke conversion, How do i hook it on Carb?
Old Jan 29, 2008 | 06:55 PM
antunez13's Avatar
antunez13
it comes with a black cap that replaces the spring choke you have , and as you pull in or out it will open and close
Old Jan 30, 2008 | 09:58 AM
Franklin2's Avatar
Franklin2
It should come with instructions and a lot of little parts and pieces.
Old Jan 30, 2008 | 05:23 PM
Franklin2's Avatar
Franklin2
Originally Posted by MER
Thanks! Is it hard to hook up on the Carb?
It takes some fiddling and patience.
