89 efi 460
Old Oct 29, 2001 | 02:48 PM
wtroger's Avatar
wtroger
89 efi 460
I pulled an tore down the 460 out of my 1989 f350 because of execessive oil consumption. I had posted earlier in the year about this and the fact that number 8 spark plug did not look the same as the others. Well when I removed the heads sure enough the number 8 clyinder was wet number 1 showed some wettness but not like number eight. the rest are dry but black. I pulled the pistons out and I cannot find a problem with the number 8 cylinder no broken or stuck rings no ring gaps lined up.
What really has me baffled is the intake is wet on the drivers side if you look down in where the plenum bolts on and I mean wet nasty black. What gives here any ideas. I would like to know what was broke so I can make sure and fix it.
Old Oct 29, 2001 | 08:59 PM
Torky's Avatar
Torky
89 efi 460
Just a thought, where is the PCV vacuum port? Near number 8? If so, could be excessive blowby from crankcase all being dumped there.
Old Oct 30, 2001 | 05:23 AM
DeenHylton's Avatar
DeenHylton
89 efi 460
Could be a couple of things: Cracked, broken or missing valve stem seal, worn valve guides, or a bad fuel injector.
Deen Hylton
Ford F250 460 C-6, K&N, Headers, Dual Exh.,Comp. Cams,Shift Kit
Pioneer CD w/Bose Speakers.
Other Passion: Blown 77 Corvette (Sorry Guys/Gals)
How I can afford to Drive the above: 93 GEO Metro
Old Oct 30, 2001 | 07:42 AM
wtroger's Avatar
wtroger
89 efi 460
I did the valve stem seals on that cylinder 90 days or so ago no help. I think I will replace the injectors. I there a good after market brand or do I need geniune FoMoCo. And I want to thank all of you for your input on this problem.
Old Oct 30, 2001 | 08:25 AM
classic79's Avatar
classic79
89 efi 460
Just go with oem injectors. No need to go aftermarket unless you are stepping up in size.
chris
79 F-150 Ranger Lariat, 2wd, RC, LB, 460 (intake, headers, cam), C-6(shift kit).
79 mustang (work in progress...its just slow progress)
98 Chevy 4x4 (work truck)
95 Lexus SC300 (wife's baby)
Old Oct 31, 2001 | 09:47 AM
wtroger's Avatar
wtroger
89 efi 460
Well we are going to go completely through this motor. I would like to end up at about 8.5 compression ratio who's piston should I look at. I will be using the Crane h-260-2 cam Crane's tech dept say it is compatible with the computer. Iam not sure what the stock compression ration is. The cam is made for 8.0 - 9.5 compression.
Old Oct 31, 2001 | 08:46 PM
masterbeavis's Avatar
masterbeavis
89 efi 460
bkuuz1
34
Jun 26, 2014 10:30 PM
slaponte
Nov 28, 2013 02:03 AM
ke7gpu
Oct 7, 2009 12:24 PM
eclypseballoons
Sep 11, 2007 06:31 PM
83 F350
Jun 4, 2003 12:12 AM
