considering a set of piller gagues - suggestions wanted
DIY Youll get alot more joy out of it. I got all the online how to install sheets i could find. Got smart on which wires to tap into for power. Prepped and painted my over head 3 guage pod. I wanted to keep my pillar hand hold. I took basically all day to do this (did the zoodad while i was at it). Took my time drilling / tapping the intake elbow and exhaust manifold. I checked and double checked each wire to make sure it was correct (dimmer, key on power etc.). Do it yourself you will get more out of it. Also have a dremel to fit the guages to the pod they are not produced perfect. Hope this helps.
I bought my gauges through Diesel Manor (vendor on the right of this page). They were very helpful. The Pillar comes in a black color and they sell a spray paint that matches the color of your interior. It took me about 6 hours total over two days to install. I am not impressed with my time and I imagine you could do it fast but that what I did. I have an 03 so I bought the Isspro black with the red pointer. It looks very clean. I am really happy with the gauges and love knowing what is going on with the engine, especially when I am towing. Go to Diesel Manor and they have a web page of instruction you can read and/or download. It will give you a good idea of what is involved. I called to place my order because I really didn't know what clamps to go with and the customer service was awesome. I would say do it yourself and enjoy the accomplishment when it is done! Good luck.
I went with a SINGLE MULTI FUNCTION gauge.
It displays a whole HOST of functions that are available thru the OBD2 bus. For your diesel you will get boost since your 7.3L has the sensor.
To get Pyro...you will have to order that sensor and feed it into one of the analog inputs.
I know you said you don't have a grab handle...but this single A-Pillar mount will still work for you and IMO is the cleanest of the install options...you can monitor 2 parameters at a time or set up a 'cycle' scan to scroll thru those you are interested in. You can also set up one parameters 'limit' that if you trip it...activates the BRIGHT LED's to get your attention.
This post https://www.ford-trucks.com/forums/6...Aeroforce+tech contains links to all the parts I used (gauge, pod, paint, etc)...
Let me know if something isn't clear.
And here's a picture here to peak your interest...
Good luck!
joe.
BTW...the parameters this gauge 'can' display are as follows:
RPM
MPH
Intake Air Temperature
Intake Air Temperature 2 (charge air temp)
Mass Air Flow Sensor Counts
Mass Air Flow Sensor (lb/min.)
Engine Coolant Temperature
Long Term Fuel Trim (bank 1 and 2 if supported)
Short Term Fuel Trim (bank 1 and 2 if supported)
O2 Sensor Voltage (bank 1 and 2 if supported)
Manifold Pressure in PSI (Boost pressure for factory turbo/supercharger
applications)
Ignition Advance
Cylinder head temperature
Engine Run Time
<ST1 class=inlineimg title="Stick Out Tongue" BatteryVoltage
Throttle Position Percentage
Throttle Position Voltage
Engine Load
Calculated Horsepower*
Instantaneous and average fuel economy*
2 user configurable analog inputs**
Injector Pulse Width
Injector Duty Cycle
Fuel Pump Duty Cycle (returnless systems)
Fuel Pressure (returnless systems)
Transmission Temperature (Automatics)
Transmission slip
Calculated Engine Torque
Injector Control Pressure (diesel)
Injector Timing (diesel)
Engine oil temp (diesel)
EGT1,2,3 (2008+ diesel)
DPF delta pressure (2008+ diesel)
Regen status (2008+ diesel)
* Vehicle must have a Mass Air Flow sensor to obtain these parameters.
** 0-5v inputs can be configured to read the outputs from MAP sensors, Air/Fuel ratio kits, pressure or temperature sensors, etc. Raw voltage can be displayed or a conversion can be entered to read proper units.
Good luck!
joe.
RPM
MPH
applications)
Ignition Advance
Engine Run Time
Engine Load
Injector Duty Cycle
Transmission slip
Good luck!
joe.
Good luck!
joe.
Originally Posted by mudmaker
How accurate is the tranny temp on that setup? I know the factory gauge is worthless.
This gauge has a very accurate degree by degree readout...now I can't tell you exactly where the OEM SENSOR is located...that one I have no idea...but I can tell you that this digital gauge reads out in degree increments...and follows what I 'know' to be the scaling on the factory gauge...basically when it hits its normal resting place...you are at 100°F...where it sits UNTIL it exceeds 220°F. So the factory gauge isn't 'lying'...it is doing what the Ford engineers scaled it to do...i.e. NOT MOVE MUCH...it WILL move over 220°F though.
But this Aeroforce gauge I have it programmed to LIGHT THE LED's if the trans temp exceeds 200°F even if I am NOT monitoring the trans temp at the time...I cannot IGNORE the LED's!!!
joe.
I am getting ready to get gauges for my pickup. I like what I see so far on your setup. I am looking at the website you referenced right now. Thanks for the info.
No problem. If I can help in any way just ask.
If you send Aeroforce an email...ask for Todd...he's on top of the info for his company...he'll usually respond within a day...
I am pleased with the product so far...I like the single gauge mount personally...
GOOD LUCK to you and the OP!
joe.
Slim,
I ordered directly from Todd at Aeroforce. Tell him you heard about it on Ford-Trucks from Joe.
He's a GREAT supplier that is supporting our Excursion/Super Duty rally in Gatlinburg...so let him know his support is APPRECIATED by letting him know where you heard about it.
His website is http://aeroforcetech.com/Fordtech.html
With the order page being http://aeroforcetech.com/Ford-order.html
Price is $239 and you get to choose your display color the face color and the bezel color...so you can match what you already have in the truck.
If you follow my link in my first post above...I've got a write up on the suppliers where I purchased the A-pillar pod and some other options...
But to cut to the chase...I purchased my pod mount from egauges.com and in particular here is the Super Duty page http://egauges.com/veh_mod.asp?VehMake=Ford&CT=Trucks
Personally I like how integrated this gauge looks...but that's just my opinion.
If I can help anyone with any questions just let me know. Otherwise tell Todd you heard about it on the Excursion forum!
joe.
joe.
Joe:
Where the guage plugs in does it hang down in the way, or is a 90* plug or something. I just know when I plug my tuner in there it hangs down quite a ways.
Excellent question...the cable I got has a 90° connector...so it tucks up nicely below the dash...
Yeah a straight connector would be horrible to make a proper bend...I can snap a picture if anyone is interested...but it is barely noticeable...I ran the connector up under the dash and out by the A-Pillar base (there is a soft rubber flap there to feed the connector up thru)...the connector that goes to the OBD2 is HUGE...so FEED the small back of gauge connector FIRST from below...
The gauge comes with a bracket to clamp the gauge to the pod...I did NOT use that incase I wanted to easily remove the gauge...it fits very snug...and if you need to be more snug...I'd just wrap a band of electrical tape around the gauge...and avoid the hard clamp...
Because once you put the pod on the A-Pillar with those push pin clamp thingies...it is NOT coming off very easily...leaving the gauge in the pod without the rear clamp gives you future ease of removal.
joe.
