Unibody door and floor help
Will the door out of a 1965 F100 Fit on a 1963 F100 Unibody. But if they dont will the door glass out of 65 F100 fit in a 1963 Unibody. And will the window cranks and the window slide out of a 1965 F100 fit in a 1963 Unibody? And where can i find replacement floor pans for a 1963 F100 Unibody?
Thanks
Thanks
Hi I dont think the doors will fit. The body lines on a uni are differant than the non unis (separate box and cab). As for the handles and glass they might work, i belive the parts are the same. For your floor pans check with Carolina Classics they have great parts. Also try Dennis Carpenter. Good luck, Justin
Links to Carolina and Carpenter
http://www.dennis-carpenter.com/
http://www.carolina-classics.com/index.cfm
ctorres
09-13-2016 07:18 AM
1963unibody
10-28-2015 07:18 PM
svolpone
08-24-2015 01:51 PM
61_F100
07-06-2015 04:13 PM
