FROM WHAT I HAVE FOUND OUT IS THEY DON'T BALANCE THE DRIVE SHAFT AT THE CARRIER BEARING I PUT A HOSE CLAMP ON THE DRIVE SHAFT AND GOT IT TO GO AWAY THEY NEED TO BALANCE THE DRIVESHAFT AT THE CARRIER BEARING.
does it matter where or just slap it on the rear drive shaft right behind the carrier bearing?
