New Headers
Originally Posted by jonbass40
cause with headers, there is no way to get the starter out of the truck without droping the trans or removing the header.
The tube might be the AIR tube for the cat. If you install headers it would not be needed, nor would the rest of the AIR system. The O2 sensor you definitely need to keep unless you like the thought of billowing clouds of black smoke and single digit mileage.
Originally Posted by Silver Streak
There's not? I've changed mine 3 or 4 times with the headers. It isn't pleasant, but it doesn't require removing anything else.
Mine are Heddman's. Like I said, it isn't pleasant, but it can be done. I keep telling myself I'm going to change to the later model starter with the smaller case, but I haven't done it yet. The starter will come out with the Heddman's.
If it has an O2 sensor it will run rich without it unless you ditch the stock carb and put one on that doesn't need the O2 sensor.
