Sooty pipes & R&R Low Pressure Fuel Pump?
Took my 6.4 in for sooty exhaust pipes and the tech replaced the low pressure pump that mounts on the frame rail part# 8C3Z-9G282-A. Does this seem logical or did they just throw some parts at it? Anybody care to offer an opinion? Just picked it up today. Should the pipes clean themselves after some regen cycles? Thanks
Mine is in the shop right now. That was one of my complaints. They replaced the DPF. service guy said they are doing some other things to it that it might be ready tomorrow afternoon. But he also said don't count on it. They have had it since Monday morning around 8. He said the mechanic said he did not want to see it come back. He was going to go through all the tsb's and do any of the ones he could. I also complained about the Limited slip and told them I did not think it was working correctly.
Your pipes won't clean themselves unless you run in the rain for awhile and road spray manages to clean them.
I know this is off topic, but thought i would throw my .02 about just going through and seeing what TSB's they can do.
I am very happy my service rider talked me out of the voluntary flash i wanted to do for truck prior to 7-30-07. Most trucks that had the flame thrower flash got the new updates with it. TSB's dont mean that that work needs to be done on your truck, there ment to help diag certain problems some vechicles may display.
If your truck needed a certain repair you would recieve a field action/ recall notice.
I have seen several people do voluntary flashes when there was no issues and what do you know, they have new issues of compliants. I guess i believe in the if its not broken dont fix it.
It's scary when they just go lookin and probin
The limited slip is an issue They rebuilt mine under warranty
Originally Posted by SANDDEMON08
I would like to hear what the service tech has to say about the revelance of the soot and the low pressure transfer pump being the root of the problem.
Thanks rob_nc, that was exactly what I thought when he told me. I was referring to the inside of the pipes where the soot is, not the outside. Should I try to clean what I can or will it burn off after some regen cycles?
Well I just got the truck back from dealer, they got it ready today, had since Monday. DPF was changed they ran diagnostics on both fuel pumps. They had the the covers off but did not say what they did. There was something on the list that they had to call tech support, but nothing about what they found out or did. Some hose had to be replaced to the cover. Said they tested limited slip according to shop manual and it was ok. The check engine light is where they had to call tech support but doesnt tell anything else. They just put quick notes on the service sheets. I wish I knew what all this was about. I quess I will have to call service advisor in the a.m. and see what they really had to do. He told me that they had the intake manifold off but nothing in the notes about that. They had the alternator off and nothing about why. They had a bunch of TSB stuff listed but no info. One of the TSB there was a statement that they did not see the reason behind the test. The truck look really nice after three days of salt spray on it. They changed the oil and filter and did the TSB for over full oil check. I did get a complimentary safety inspection so they say. Time will tell.
Bill in KY
Originally Posted by hodgekuter
SandDemon08 how do you like your '08 6.4 I just bought one after having an '01 7.3 and then a new '05 6.0. So far I really like mine.
Bill in KY
Bill in KY
