It is actually leaking after 2 years. The bulged area cracked and hose clamps don't seem to put uniform pressure on the tubing. I can either repair the joint every 2 years or put a compression fitting. Thanks for the suggestion. I will see if I can find a right size fitting for the aluminum tubing.
