Humming noise with hubs locked
#31
Originally Posted by nighthawk285
I would check your hubs Chris, maybe just pop em off , make sure that everything is engaging/disengaging right, clean em, and put em back in. I had a grinding noise on my drivers side hub this summer, took it apart, and the spring had fallen out of its seat, not letting the hub disengage all the way and the splines were grinding together.
Just make sure you have lots of shop towels, brakekleen, and then grease if you go far enough to need to maybe repack bearings (might be a good excuse anyways)
#32
hmmmm.........you got me grasping at straws here, but if your hubs are good, then I am thinking your problem might be in your centersection. So two questions, does that shop have a warrantee program and if so, is it still valid? If it is, take it down there and tell them whats up, hell call and ask them anyways, since they put it in, they might have some ideas that we don't as well. Best of luck, I'll be watching to see what you find
#33
#34
Just found my receipt and read the warranty terms on the back... Doesn't look very hopeful...
http://i170.-----------.com/albums/u...20Swap/IMG.jpg
#35
........sorry to say, but, with those "fine" print's for showing[ what you had shaded], about's your warrantee for your work done, thing's DON't look too hopeful upon the service people you had the work perform'd....... . . . . I don't want to point the "bad" off hand, but just maybe might be good people for there and they "Might" checkout and all for you and "Possibly" render a fix / repair with_in reason to your like-ng's........ i feel for your prob tho, Chris........
mr. Charles
mr. Charles
#36
#37
Chris, did you ever end up cutting a piece out of your TTB where your axleshaft was rubbing?
I had a similar humming when my hubs were locked. Went through and changed out all the u-joints, axle(3) and driveshaft(2). My axleshaft joints were pretty bad as they were original. The hum did go away though.
Start with the easy ones first, the driveshaft.
Talk to the shop that did your gears and see if they recommend a break-in period, if it doesn't go away in that amount of time, let them take another look at it.
#38
CapeFerreloMetal
1999 to 2016 Super Duty
08-26-2013 03:50 PM
shore
09-29-2010 10:46 AM
l67cooled
12-29-2009 04:53 PM
