Blue smoke While idling
Old Jan 21, 2008 | 10:24 PM
Dieselguy89's Avatar
Dieselguy89
Unhappy Blue smoke While idling
I have a 92 7.3L f250 with 345,000kms and it smokes blue out the back
it helped a bit when I changed the fuelfilter,oil and oilfilter but still smokes injectors never changed and I am not to sure about the Injector pump. Also there is no tail pipe on it from the previous owner not sure if this would be some cause of the problem, It runs strong and has power just smokes blue
Old Jan 21, 2008 | 10:48 PM
PLC7.3's Avatar
PLC7.3
Well overdue for some fuel system service for sure......
Are the injection return lines and injectors grey painted.......
Timing would be considered if blue smoke smells like fuel, oil if it smells like oil.
With that mileage the injectors could be firing too early due to being worn and a worn IP .
Read info here.......... http://www.intellidog.com/dieselmann/idi.htm
Old Jan 21, 2008 | 10:58 PM
Dieselguy89
Yes the Injector lines and the injectors are painted grey,
the blue smoke does smell like oil a bit and unburnt fuel, How can I set the timming on the Injector pump
Thanks
Old Jan 21, 2008 | 11:40 PM
PLC7.3's Avatar
PLC7.3
Not any sense to retime ...if they are original as there will be too many varying pressures on the injectors now.
Only time to retime an engine is when new IP and injectors are installed.....
Old Jan 21, 2008 | 11:51 PM
Dieselguy89
Ok thats wat I was thinking but was unsure, Wat does it take to replaceing the old Injector pump.
The Injectors seam prety easy. also I seen some off ebay for a decent price.
Do you know or know of if they are almost good as the ones u buy at stores
Thanks
Old Jan 22, 2008 | 02:53 AM
fonefiddy's Avatar
fonefiddy
I'd recomend staying away from Diesel Direct
